Ignition switch mounting?
Drew13
i just replaced my ignition switch and the person who i bought it from had an aftermarket switch in it. I put an original style switch in and was wondering how to mount it to the dash. do i need an igniting swith bezel? or do i need more to mount it?
S_bolt19
Colorado
you should be able to stick an original ignition switch through the ignition hole on the dash. nothing more should be needed. just take the lock nut off the switch and slide it through the hole, put the nut back on and you are good to go.
79' Buckin Bronco
