i need to replace the headlight HOUSING
Xearo69
yah somone put a new bulb in the cylindrical thing and didnt ***** it into the headlight housing, they just left it partially in the housing and the bulb melted it so now i cant ***** the cylindrical thing into the housing since its melted and warped.. the housing -how do i take that out? do i have to turn those three ajustment screws till it comes out?? cuz one of em is messed up and its the one that goes all the way down to the bottom of the housing.. hmmmm.. if only i had a dremel...
bluefordcat
SOUTH DAKOTA
there is a special tool to remove 3 clips that removed the headlight capsule. I started to try changing mine , & just knew i was going to tear something else up so I took mine to the body shop and watched them change it ..@ 2 1/2 hours later they got it done. It was a pain in the a**
X
Xearo69
ok i got one off at the junk yard.. not to difficult.. i had to take off the metal fram behind the housing tho.. yah it was difficullt but mostly cuz i had to turn the adjutment allen ***** like 40 turns till all the threads had turned out. and it keeps jumping if u apply to much torque.. ***.
denny.dikes
