HUB
broncoarg
Hi , i have a little problem whit my right hub (bronco 81), here in my country (argentina) i have to pay about u$s 300 for a new pair..is very expensive and difficult so my question is...anybody know about the repair kit or cheap hub or anything? THANKSSSSS
You can buy directly from Warn
WARN STANDARD MANUAL HUB - WARN Standard Hubs are the ideal choice for OEM hub replacement. These are the same basic hubs Warn Industries has supplied to OEMs around the world. WARN standard hubs share many features with their premium hubs such as a 4140 steel clutch ring and inner drive gear and a precision cast hub body.
Specifications:
Manufacturer: Warn
Category: STANDARD HUB
Make: FORD
Model: BRONCO
FitYears: 1966-1996
Part Number: 9790
Additional Information: (Set; 19 Spline;) -
click to view footnote(s) B-1,G-2, E-1 These do not apply to your year
Price: $73.95
FROM OUR SPONSOR HERE!:
Item #32127 - New
Warn Standard
1980-96 Ford Bronco
1980-96 Ford F150
D44 STANDARD MANUAL HUBS
WARN standard hubs share many features with our premium hubs such as a 4140 steel clutch ring and inner drive gear and a precision cast hub body.
NOTES:
* Will Not Fit '87-Early '88 Models Vehicles, ****** Mount
* Vehicles With Full Time 4WD Requires Transfer Case Conversion Kit
* When Replacing Automatic 3 Hole Cap ***** Hubs, You Must Purchase Corresponding Spindle Nut Conversion Kit
Our Price: $70.00
or from internet:
Warn Standard Manual Hub Kit 9790 $64.95 - StreetSideAuto.com
I'd buy from Jeffs!
or a SERVICE KIT: I'd buy from Jeffs!
WARN STANDARD MANUAL HUB SERVICE KIT - Standard Manual Hub Service Kit. Services a Pair of Hubs.
Specifications:
Manufacturer: Warn
Category: STANDARD HUB SERVICE KIT
Make: FORD
Model: BRONCO
FitYears: 1966-1996
Part Number: 11967
this is the KIT--
or buy from an on-line store;
such as:
Warn 11967 Standard Manual Hub Service Kit $27.41 - Amazon.com
or
http://cgi.ebay.com/ebaymotors/Warn-11967-...011310008r31390
watch their Shipping Costs!
You'll also need the Spindle Nut Socket, Dana 44
# 29625
New Price: $15.00
Tourque wrench, etc.
see my Bronco site for replacement info, such as:
[url="http://Wheel%20Bearing%20Locknut%20Torque%20Settings%20for%2080-96%20MANUAL%20HUBS,%20NOT%20Factory%20Auto%20Hubs;%20Ford%20Pickups%20and%20Bronco;%20"...Using%20a%20lockout%20spanner%20(ford%20#%20T59T-1197-B%20or%20equivalent%20)%20and%20a%20torque%20wrench,%20tighten%20the%20inner%20bearing%20adjusting%20nut%20to%2050%20foot%20pounds%20while%20rotating%20the%20wheel%20back%20and%20forth%20and%20seating%20the%20bearing.%20Back%20off%20the%20adjusting%20nut%20approximately%2045%20degrees.%20Assemble%20the%20lock%20washer%20by%20turning%20the%20inner%20lockout%20to%20align%20the%20pin%20with%20the%20nearest%20hole%20in%20the%20lock%20washer.%20To%20lock%20it,%20install%20the%20outer%20lock%20nut%20and%20tighten%20it%20to%20150%20foot%20pounds.%20Grab%20the%20top%20of%20the%20tire%20with%20one%20hand%20and%20the%20bottom%20of%20the%20tire%20with%20the%20other.%20Move%20the%20tire%20in%20and%20out%20on%20the%20spindle.%20End%20play%20should%20be%20less%20than%20.006%20
broncoarg
Great!!!!!! thanks, so whit the repair kit will be fine? i hope that...bye !
yw
dunno.. did you take the hub apart? could be just a bad c clip or needs cleaning an LIGHT lubrication.
also, I was assuming it is a manual hub...
A lot of dolks here may have what you need.. can save you some $$$
find out what you need and post it here as well as in the Parts for Sale or Wanted Section.
broncoarg
yes is true...so i will see it an then i'll post a photo...thankss
rcarm74
