Got into this biz somewhat by chance surfing classifieds, ran across this '91 model that was advertised at a fair price and supposedly had just 44k miles on it & in running condition.
A look-over revealed neglect in certain areas and been sitting outside had taken its toll on all the exterior rubber trim.
On the plus side- the body was straight, the interior was good, almost everything was still with the vehicle, no rust, fairly new tires and a E.B. edition?
Ok
A quick negotiation, swaps hands, drove it up on the trailer & go home.
After I got the thing home and began to nose around the inside, found a sheet of paper that had a list as to what had been replaced on the vehicle that says the fuel tank and innards had been changed out along with the starter, water pump, alternator and some other minor things.
Almost a 'barn find' but not quite.
4X is inop along with the windows and dash lights. Had to change the lower seal out in the steering sector and will be replacing the muffler somebody tore off with a Flowmaster 50. While the 351 does run, it is going to require some evaluation/compression test to see if a freshen-up is required. Smoked the first few times it was started, but the more I work with it, the better it seems to get. After changing what looked like 15 yr old diesel engine oil out for some fresh Rotella, the last few runs have resulted in no more smoking. (add new fuel & treatment/cleaner for more testing)
It would seem that this vehicle has sat for a length of time as the fuel tank has been replaced. (Shiny metal there)
The title shows the mileage to be accurate and the more I dig into the thing, the more convincing it is that this vehicle is a bit of a Time capsule.
What I don't understand about the maintenance sheet is nobody ever seems to have given any thought to the valve cover gaskets. Looks to be OEM as there's plenty signs of oil leakage over the years- it is mighty nasty down underneath & on the transmission. Going to take a lot of cleanup down there.
Let the rehab begin
Ok
Let the rehab begin
