Horn wiring
Ditch Jumper
Greetings I bought a 71 bronco and the horn does not work, I did not want to put one of those push buttons on the dash unless it was last option, does anyone know where I can find the wiring schematic of the horn and relay or have instructions on fixing this problem. thanks
There's a plug coming fr. the steer. column where it meets the dash. (bottom) Make sure the male & female ends are clean. (Lime away & a Q-tip work good, then oil))
Use a volt meter at horn ....honk & see if the needle deflects....if so, horn may need cleaning or replacement.
