Maybe the hood is warped or was not made right. I,d mearsure it really good and have a good look at the hinges.need some help figuring this out. i see that the front clip on the passenger side is 1/2" longer but it doesnt close the gap up when moved. i can pull the front clip over to the driver side and close gap up but then the frame mounts are totally off and my doors to fenders line isnt bows inward.
View attachment 28143View attachment 28144View attachment 28145
Has it been in a wreck and had the front -end hit on the front part sideways?Maybe the hood is warped or was not made right. I,d mearsure it really good and have a good look at the hinges.
Everything up front is new floor, firewall, kick panels, windshield cowl, aprons, hood, etc i just cant find what part isnt right to correct it, everything is measuring with 1/8-1/4 of the other bronco sitting next to it. Except the 1/2” from from cowl to core supportHas it been in a wreck and had the front -end hit on the front part sideways?
I noticed the door sides looked like one was out more then the other one. Sometimes thes alignments can be a pain to figure out. How does the doors align to the back of the doors?Everything up front is new floor, firewall, kick panels, windshield cowl, aprons, hood, etc i just cant find what part isnt right to correct it, everything is measuring with 1/8-1/4 of the other bronco sitting next to it. Except the 1/2” from from cowl to core support
I focus on the core. Look at it from different angles. Top--bottom and both top and bottom of core. I d have another look at those doors. Take your time and look at it all carefully. Its easy to get a measurement wrong. Especially when someone is talking to you.Everything up front is new floor, firewall, kick panels, windshield cowl, aprons, hood, etc i just cant find what part isnt right to correct it, everything is measuring with 1/8-1/4 of the other bronco sitting next to it. Except the 1/2” from from cowl to core support
Thanks Mike. Very informative.Yo Rossr,
Part 2
My part 1 post for fenders and hood isn't visible because it requires moderator approval, although I'm a f☆☆☆jng moderator!
Door Inspection
To determine door alignment requirements:
- Check that the front door contour is flush with the body contour.
- Check that the body-to-front door gap is the same around the whole door.
- Determine by observation of the door alignment what adjustments, if any, are required.
Door Alignment
Hinge Assembly
CAUTION: Do not cover up a poor door alignment with a door latch striker adjustment.
The door hinges provide sufficient adjustment to correct most door misalignment conditions. The holes of the hinge and/or hinge attaching points are enlarged or elongated to provide for hinge and door alignment.
- Determine which hinge bolts must be loosened to move the door in the desired direction.
- Loosen the hinge bolts enough to permit movement of the door with a padded pry bar.
Front Door Hinge Adjustment, Bronco, F-150, F-250, F-350 and F-Super Duty
View attachment 28149Striker, Door Latch
- Move the door the distance estimated to obtain the desired fit.
- NOTE: The door latch striker can be adjusted laterally and vertically as well as fore and aft. The door latch striker should not be adjusted to correct door sag. The door latch striker should be shimmed to get the clearance shown between the door latch striker and the front door latch. To check this clearance:
Clean the front door latch jaws and the door latch striker area.
- Apply a thin layer of dark grease such as Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B to the door latch striker.
- As the front door (20124) is closed and opened, a measurable pattern will result.
- Move the door latch striker assembly laterally to provide a flush fit with the front door and body. Do not use more than two shims.
Hinge, Door and Tailgate
- Using an appropriate Torx® bit, tighten door latch striker to 40-50 Nm (30-37 lb-ft)."
Use Multi-Purpose Grease Spray D7AZ-19584-AA or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C106-B to lubricate door and tailgate hinges. Apply an even coat to all hinge pivot points as outlined in the maintenance schedules or when a binding or squeaking condition occurs.
I thought this was for a 1991 Bronco! W
Everything is newWith restoring a old vehicle. Before trying to lignment. I,d think I would check for wear in the hinged. If the were worn. I,d replace them and go from their. I don,t think I saw a year he is working on either.
Its a 1969. I posted it in the 66-77 tech so i figured that part was self explanatory lol but I understandEverything is new
Well I could have over-looked it too. What kind of shape are the hinges in?Its a 1969. I posted it in the 66-77 tech so i figured that part was self explanatory lol but I understand
The hinges might be your problem. I have heard of the causing a lot of problems. Hope that is it.Well I could have over-looked it too. What kind of shape are the hinges in?
Brand newThe hinges might be your problem. I have heard of the causing a lot of problems. Hope that is it.
Did you compare them to the old ones? You know how much you can rely on things made now days. I, d check them.Even measure them.Brand new
Little things like that can be a pain in the a -- and make a person mad. Or someone comes along and sees the problem and tells you.Did you compare them to the old ones? You know how much you can rely on things made now days. I, d check them.Even measure them.
I agree w/ johnnyreb, it is almost for certain one of these, especially the front frame damage. Look under your Bronco and you will see some rectangular holes on the bottom of the frame, if they look distorted there has been frame straighten from a wreck or roll over. This is quite common to see.Has it been in a wreck and had the front -end hit on the front part sideways?
Yo,Its a 1969. I posted it in the 66-77 tech so i figured that part was self explanatory lol but I understand
