HELP
hans
ILLINOIS
I HAVE A 89 F-150 WHEN U GET UP TO 35 MPH IT STARTS TO BOUNCE DOES ANYONE KNOW WHAT IT COULD BE
jstevenson509
Spokane, Washington
I'm certainly not one of the most informed on this site, but I know I had an old ranger and the rear wheels were misaligned causing it to shudder at higher speeds (over 55).. pretty cheap fix. My first guess would be to check tire tread wear.. That can sometimes tell you a lot.
Yes, check for any bad spots on the tread of a tire, or a missing wheel weight throwing the tire out of balance. If you still have the stock rims, they are bad about getting bent, JSM84
crazyhorse85
clarksville,tenn
I agree with both answers...a bent wheel can cause a major headache....and so can a busted belt in a tire....have your alinment checked and while they are at it have your tires and wheels balanced...(preferrably spin balanced).....hope this helps some.... B)
Bronconewbie
Is it supposed to do that???
So. ILL.
If you don't find anything with the tires, Jack up your truck and put it on jackstands, or if you have access too a lift, get all four wheels off the ground. Put one hand on the front of the tire and one hand on the back. gently shake tire back and forth to see if theres any play in your tie rods. After that Put one hand on top and one hand on bottom and repeat shake to check play in ball joints and wheel bearings. I usually find its something pretty simple most of the time its just wheel bearings needing tightened.
Virgil3rd
