Help with water pump bolts
vivalaporkchop
Well im still new to this and working on rigs myself as it is but here we go. I was removing the water pump and the wonderful truck gave me the issue of a snapped bolt. Go figure right?? Im sure your all surprised. Well since that one snapped i dont know how long it is and I bought a stud kit from napa and it had 2 studs and 1 bolt which the bolt worked fine but the studs were the issue. One was a rather short one and i couldn't get it to grip in any of the holes i had remaining cause i thought that was the one i snapped. i did it get out by the way. Im just trying to figure out if the kits from Napa or any other auto shops would the correct ones or not cause i am completely lost right now. Thanks for any help you guys give.
"I did get it out by the way"
That's good..! Clean out any female threads in the block. Use any bolts you may have to ***** in & match the threads. Hardware & auto parts stores should have single studs.
Length can be determined by measuring the depth of the hole, add for the thickness of the waterpump, & any brackets that go on top. Add 1/2" for the nut & lockwasher.
At the boat shop, we used a goo to coat any bolt threads that were exposed to, or could be exposed to water to prevent rust/snapping.
Auto parts may have a waterproof product like this.
As a rule, I never ***** anything into waterjackets on an eng. block W/O sealing the threads. >:D< <'>
BobButtertone
