Help With 1983 F150
firelt90bronco
Ask me about my job
northeast
I'm a mechanic on the side and I'm working on a 1983 F150 that I swapped a 302 for a 351 because it seized. The truck has a new ignition box, distrib cap and rotor, plug wires, spark plugs and new coil from the 302. Still no spark. The engine is TDC and battery is charged, where do I go from here, some wiring and vacuum ports are not connected, does anyone have pics or a diagram of igntion wiring? Or anything I overlooked?
va92bronco
33931[/snapback]
Make sure your ground strap is connected and secure. Other than rechecking all of the wiring, that is my best advise. Is it a OEM ignition box or a/m?
F
firelt90bronco
Ask me about my job
northeast
By grounding strap, do you mean negative battery cable? Because that is frayed beyond all belief and I'm insatlling a new one tomorrow. The ignition box is OEM and the wiring harnass needs to be replaced.
$100.00Bronco
Tooele, utah
33937[/snapback]
There should be a ground strap from the engine block to the firewall. It should be on one of the bolts that bolts the trans to the block. If that is missing it will not get spark.
Good luck, Dennis
F
firelt90bronco
Ask me about my job
northeast
Well, I think the wiring harness that connects from the ignition box to the distributor is really screwed up, frayed wires, spade plugs, electrical tape, etc.
F
firelt90bronco
Ask me about my job
northeast
Acting captain now. Thanks for the diagrams, does anybody have a flare and some gasoline, damn truck!
Ford644
