pinaydyosa
Ok let me correct my questions; after consulting w/ my father he told me what questions to post specifically.
1. How do you tell if the low pressure fuel pump is working?
2. How can I test the low pressure fuel pump to tell IF it is working?
3. If I disconnect the line between the High and Low pressure fuel pump (note: low pressure pump is located in tank) when I turn key switch should the low pressure pump still push gas out of the tank?
Any light anyone can shed on this matter would be GREATLY appreciated!
