Help tracking down E40d tranny issues/After searching
Selkirk
OK here's one more transmission request. I have been reading the prior post and have come down to the following point.
Transmission goes into safe/limp/hard shift mode on a now-and-again pattern.
Sometimes it goes days/week between safe mode and other days it might do it four or five time in a row and then quit. Other times maybe once then shifts fine the rest of the day. Really no pattern at all.
State of the Bronco
Six month old new to me Bronco-only history was that it was yearly serviced by the dealer
144000 miles
1994 EB
No codes-I own a code reader
Speedometer/gages all work
O/D light is not flashing
Airbag light started flashing a code a week ago.
I did the following based on searches on this forum. Listed in the order which we performed them.
Cleaned the VSS on the differential
Replaced the VSS on the differential
Replaced the MLPS with new style connector
Drained trans/TC replaced fluid/filter and added drain plug
Drained and replaced differential fluid. (Very little sludge buildup in old fluid.)
Lightly checked for chaff/broken wires (any hot spots for rubbing?)
At this point a could use a little help in which direction to go. The issue (safe mode) come up at such erratic times I having trouble pinning it down. My first thought is it must a loose/rubbed wire or connection somewhere.
Any help would be great
Selkirk
BroncoJoe19
Did you pull KOER codes?
I think the three sensors that are most important for the E4OD are the VSS, TPS, and MAP (which would act as an engine load sensor, if you have MAF in a 94, I'm not sure what acts as an engine load sensor)
Also a fully intact vacuum system. Did you check for vacuum leaks?
rcarm74
