We checked this too. Fuel pump runs as well.I'm not a Bronco II guy, but Ford doesn't do a lot of reinventing the wheel so the systems between vehicles are the same or similar. Can you hear the fuel pump come on when you turn the key? If not, have you checked the inertia switch? It is generally on the passenger side under the dash, (a small square box with a white button). 80's Ford EFI engines had two fuel pumps, one in the tank and the other on the driver side frame rail.
Was anything done on the vehicle just prior to the problem?
