Heater Problems
Thomas 714
Greenville, Ohio
:ph34r: /emoticons/[email protected] 2x" width="20" height="20" /> Where does the heater control gets the vacuum from. My 79 Bronco has a new motor and the person who put it in before i got it took off the poluction stuff.
So what is the sourse to make the vacuum to work the heater controls.
Can anyone give me some imput on this?
R
raskew
Guest
What year of Bronco do you have? and what exactly is the problem you are experiencing?
Rick
Ziggy
Riverside, Ca
A vacuum line feeds through the firewall and T's into a another line. This linethen goes to the back of the engine and the other side goes the vacuum resevoir on drivers side of engine compartment. As your looking into the engine compartment, line should be just to the right of the center line of the engine, just above the engine. Look for disconnected line or you may have a leak in your resevoir.
david@holycitytransportat
