What happens when brake lights flicker while driving up hill and when on level road?
If flickering; you need to go thru the electrical brake/turn Circuits; Ford suggests a "wiggle test" on connectors and harnesses
Hazard, Turn, High & Low Headlight Dimmer, Flash-to-Pass, Multi-function Switch (MFS) & Brake Light Testing & Wiring Diagram in 92-96; Hazard, Turn, High & Low Headlight Dimmer, Flash-to-Pass, Multi-function Switch (MFS) & Brake Light Testing & Wiring Diagram in 92-96; "...
the MFS testing is done with connectors disconnected; it's strictly an internal test of the MFS;
Miesk5 NOTE; Brake Light & Turn, High & Low Headlight Dimmer, Flash-to-Pass & Hazard CKTs are a Feed-Through Circuit in Multi-function Switch (MFS). The turn signal system is deactivated when the hazard flasher system is on. Turn signal lever motion does not affect the hazard flasher system. The hazard flasher system operates independently from the ignition switch (11572). All turn signal lamps can be made to flash in unison by depressing and releasing the hazard actuator located on the top part of the steering column. The switch is identified by a double triangle symbol. The actuator will move out or away from the steering column tube (3514) to the ON position. The hazard flasher system is turned off by first pushing in the actuator and then releasing the actuator. The actuator should remain in or toward the steering column in the OFF position..."
Source: by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/registry/media/225114_1
Also,
torque converter test;
This test verifies that the torque converter clutch control system and the torque converter are operating correctly.
1. Carry out Quick Test with scan tool. For additional information, refer to the Powertrain Control/Emissions Diagnosis manual (PCED). Check for DTCs.
2. Connect a tachometer to the engine.
3. Bring the engine to normal operating temperature by driving the vehicle at highway speeds for approximately 15 minutes in (D) position.
4. After normal operating temperature is reached, maintain a constant vehicle speed of about 80 km/h (50 mph) and tap brake pedal with the left foot.
5.
Engine rpm should increase when brake pedal is tapped, and decrease about five seconds after pedal is released. If this does not occur, see torque converter operation concerns. 6. If the vehicle stalls in (D) or manual 2 at idle with vehicle at a stop, move the transmission range selector lever to manual 1 position. If the vehicle stalls, see torque converter operation concerns.
7. If the vehicle exhibits a vibration during the road test complete the Road Test Evaluation Form. This form will aid the technician in determining the source of the vibration.
If the shudder occurs a) during the 3-4 or 4-3 shift at HEAVY throttle,
or B) at 40mph in 2, OD OFF,
and OD, or c) at the same RPM in every gear,
or d) coasting, cruising, or in R, or e) during extended light braking, then it is NOT TC clutch shudder.
The following is a list of common vehicle concerns that have been misdiagnosed as torque converter clutch shudder. For diagnosis of the following items, refer to the appropriate sections of the workshop manual and the Powertrain Control/Emissions Diagnosis manual (PCED).
> Spark plugs - check for cracks, high resistance or broken insulators.
> Plug wires.
> Fuel injector - filter may be plugged.
> Fuel contamination - engine runs poorly.
> EGR valve - valve may let in too much exhaust gas and cause engine to run lean.
> Vacuum leak - engine will not get correct air/fuel mixture.
> MAP/MAF sensor - improper air/fuel mixture.
> HO2S sensor - too rich/lean air/fuel mixture.
> Fuel pressure - may be too low.
> Engine mounts -loose/damaged mounts can cause vibration concerns.
> Axle joints - check for vibration.
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.
Look Codes up in my broncolinks.com site using the new Search function.
And Post em here according to:
KOEO
KOER
