gas tank
oldtimer
northern michigan
im putting new rear spring hangers on my 92 bronco. i put grade 8 bolts in thru the back side of the frame. once i was all done the front top bolts on the bracket and the leaf spring bolts over lapped by about an inch. so i was wondering how far i can drop the gas tank without disconnecting the fuel lines and the electrical lines. im hoping for about 5 to 6 inches is that asking to much. I have a full tank of gas and now where to put the gas so i have too do this without spilling any any help would be helpful
88horse
madera
ummm can you drive around until it gets low?
if not take the filler hose off of the gas tank and syphine it out with a hose
Yardape
Alberta
you can unhook your fuel lines and ground your fuel pump and let it drain the tank into Jerry cans
BroncoJoe19
New Jersey
I noted that you stated that you have no place to put the fuel.
How far away are you? I can arrive with an empty tank, you can put it in mine... no charge! :) /emoticons/[email protected] 2x" width="20" height="20" />
Maybe a neighbor would be willing to buy some from you.
O
oldtimer
northern michigan
thanks for all the help guys i bought an oxy/ace torch and cut the ends of the bolts off she should be back on the road in a couple of days i hope buy tues.
