Fuel injectors ?
bigtrux
Murrieta,CA
How can you tell if the fuel injectors are working properly I'm still trying to get my truck to start . i know i have fuel on the rail. it seems to have spark. so the only the i can think of is the injectors. but like i said before it all worked fine before i replaced the motor... :angry:
bigtrux
bigtrux
Murrieta,CA
WELL I DON'T K NOW IF THE TIMING IS SET CORRECTLY I CAN'T GET THE b!@$CH STARTED I LINED UP THE BALANCER ON 0' TDC RIGHT AND THE DROPPED IN THE DISTRIBUTOR . IT THE ROTOR WAS ON THE #1 WIRE. IT STILL WON'T START . LIKE I SAID BEFORE WHEN I FIRST GOT THE TRUCK IT STARTED NO PROBLEM EVERY TIME THE ENGINE ITSELF WAS SHOT. SO I PULLED THE MOTOR AND BOUGHT A REMAN MOTOR FROM ADVANCE AUTO PARTS I BOUGHT MANY NEW PARTS BUT I USED THE OLD DIST. COIL INTAKE AND INJECTORS... WHICH WORKED FINE BEFORE . I KNOW I HAVE FUEL ON THE RAIL. I'M GOING TO RECHECK THE COIL AGAIN . I RAN OVER ALL THE CONNECTIONS TO MAKE SURE THEY WERE TIGHT . I TOOK MY TIME PUTTING IT TOGETHER TO ENSURE I DIDN'T MESS ANYTHING UP . I'M GOING THROUGH BRONCO WITHDRAWS THIS CRAP SUCKS I'VE WAITING YRS TO GET ANOTHER BRONCO SINCE I SOLD MY OTHER NOW I GET ONE I CAN'T DRIVE THE THING ... ANY ADVICE WILL BE GREATLY APPRECIATED THANKS IN ADVANCE. :mad:
Yah,
I PM'd you... I'm thinking you just got the dizzy stabbed on the exhaust stroke.
(this is quite common...there's a 50/50 chance of hitt'n it the 1st time, BUT, 100% sure it'll be wrong..the 1st time..!)
Just be sure it's stabbed with #1 TDC on "compression" stroke....should start right up.
bigtrux
bigtrux
Murrieta,CA
I hope so my friend's coming over today he had a similar situation and said he had to do a couple of other things so we'll see i'm not gonna quit today till it starts... thanks for all the help..
snowman74
Oklahoma
How'd it turn out? What was the problem?
Snowman74 :)>-
mbtech2003
cape cod, mass
anybody know the stock lbs for a 95 351 fuel injector is i need to step it up a notch to help with the bigger cam, plus mine are leaking down :( /emoticons/[email protected] 2x" width="20" height="20" />
thanks
josh
snowman74
Oklahoma
Elmomo
