LS is a funny thing. It is there when you need it and isn't there when you don't. Not always will it engage when you do a burn out or such. The Trac-loc that Ford used in EBs was also not overly reliable. My uncle has front & rear factory trac-loc and it is not a huge, major added benefit. Yes they are better than open diffs, but they aren't anywhere close to a Detroit, Aburn or an ARB. That said, the trac-loc is put together with a "clutch" pack system and when they go out, it is the same as having an open diff. IF this is the case, then I wouldn't even bother trying to replace the original clutchs in it. I would either drive it or save my nickle and dimes and get a true traction device. As to what you want, it depends on what you use your rig for. If it is a daily driver, like mine, I would spend the extra money and get an ARB. They are almost double the cost of a Detroit or similar locker, but in the long run, there is less wear and tear on your vehicle and it will also pay for it's self the first time that you buy a new set of tires after you install a Detroit. If you are strictly an off road vehicle, then go for the full time locker.
