fender flares
guitarfreek92
alright im trying to decide weather or not this is a good idea. i do have rust along the wheel wells would putting fender flares be a good idea? if so should i try to put some rust eliminating stuff on before? ill post pics up tomorrow so you can see how bad the rust is.
yo guitarfreek9
I fought that rust in that area for years until I replaced the rusted and beyond (went up and to both sides a few inches) sexctions w/Patch Panels.
To save $, look in my site @ http://www.broncolinks.com/index.php?index=459
for the Hot LInks to such as;
Flare Info & pics (from a semi & modded) in a 91 Centurion
Source: by David B (dblue, One Ton 91, Centurion) at SuperMotors.net
Flare Info & pics in an 81; "...I wanted to install fender flares in my truck but they are not available in my country (Argentina).....so I got a set of cheap Warn flares in bad shape and sent them to make a copy.....Today I got the first set and installed them....the cost for each set it will be about $100.- bucks!!..."
Source: by Henri at uc4x4.com
Flare, Bushwacker Cut-Out Info & pics in a 94
Source: by Torvald at SuperMotors.net
Flare, Bushwacker Cut-Out Info & pics in an 86
Source: by Damager (Da Bonco) at SuperMotors.net
Flare, Bushwacker Cut-Out Installation Instructions; 78-96 "...This Flare adds 3¾" of tire coverage; Front Part # 20021-11, Rear Part #20022-11; Available in a no pocket cut-out design; Offers extreme tire and wheel coverage, allowing you to increase the wheel well opening to accomodate large tires and wheels; Exclusive Dura-Flex® material fives maximum durability and flexibility while maintaining its shape during extreme conditions; OEM matte black finish, or easily custom painted to match or accent any vehicle..." Instructions also available for various Flares in 78-79, 80-86, 87-91, & 92-96 Source: by bushwacker.com
Flare, Bushwacker Cut-Out Instructions & pics in a 93
Source: by bigbroncojeff (Jeff J) at SuperMotors.net
Flare, Bushwacker Cut-Out pics in a 94
Source: by RNUOVR at SuperMotors.net
Flare, Modification; "...Heres what jeep flares look like, i went to the junkyard and they let me have 8 for 30$ and i only used 2 on the back, just marked it for the flare contour, got out the old air nibbler and i like the way it turned out....but my main reason was to cut off the rusted thru parts of the quarter..." pic is gone Source: by sparkysmotorsports at karting.4cycle.com
Flare, Modification; "...i used flares off of a 98 ford explorer sport 2 door 4 door wont work. the fender radius is almost the same. only mods i had to do was where the "V" shape is towards bottom of truck i had to slightly mod the flares by cutting them with a die grinder. the ***** holes along the fender lip also matched up nicely. it tooka couple of days of trial fitting but they look nice. and along the top i instaled small bolts so they look the pocket flares made by bushwacker. this was necessary to hold them tightly to the body. it cost me a total of 50.00 to put these on. flares where 30.00 at pull a part auto wrecking..." Source: by shad351
Our sponsor here Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Jeff also has the patch panels http://broncograveyard.com/bronco/c-1163-bronco-92-96.html
& Fender Flares http://broncograveyard.com/bronco/c-193-fender-flares.html
BobButtertone
