exploded EGR coupling (pics)
LogansLost
i think i've found the source of my "exhaust leak" on my 1996 5.0 bronco. part of the EGR system looks like it blew apart some time ago and that has been what has been making noise, spewing carbon from the exhaust all over the firewall, etc. i did some googling and it appears that this is pretty common but i can't really tell what needs to be replaced exactly.. anybody have any experience with this type of problem? i haven't been able to find a good diagram or anything like that yet so i don't know exactly how it all goes together but as far as i can tell that hose should be attached to that coupling.
I had same one blow out due to rust 3 yrs ago; sounded like I had a cracked exh manifold or pipe.
it is a Secondary Air Check Valve
See this diagram to confirm; I am outside and da glare on da screen is killing my eyes
Secondary Air Injection (AIR) System Diagram, 5.0L
Available @ NAPA, etc.
here are pn's
Ford part Number; in Vehicle Emission Control Information (VECI) for 88 and up, PUK (49 States) Decal, PGP (Canada) Decal, Vacuum Diagrams & Calibration Parts List for 88 & UP - if hot Link does not take you direct; CLICK Quick Guides Scroll to bottom; Provides Vehicle Emission Control Information (VECI) and a related calibration parts list. Enter applicable info (need to know your Calibration number off of your PCM)
Source: by Ford motorcraftservice.com
btw, top 2 Calibrations show same pn for the Valve.; last one shows ( E9VZ 9A487-A ) which is Female threaded connector with valve. Replaces O.E. E9VZ-9A487-A. 5.0 and 5.8 cyl. Retail Price: $22.05
"]at PCI PN 37
PCI Part # 39 {FORD CHECK VALVE #E8DZ9A487A}
Category: Air Check Valve
$6.45
btw, PCI makes vg products incl the Ford OE Replacement Catalytic Converter Air Tubes, this Exhaust/Air Check Valve, Muffler/Converter Straps, Hangers, Brackets; Ford OE Replacement A.I.R. Manifold Tubes
Great Customer Service as well; you can buy their items @ some parts stores or direct.
PCI, Inc.Pollution Control Industries
