Exhaust leak
WileE7
I installed shorty headers and there is about a 1/2 gap between the header and the y pipe towards the back looks like this < and a slightly smaller gap on the passenger side what can i use or do to fix this i tried RTV and it just got blown out any suggestions I would intsall the old headers but they have been trashed
BroncoJoe19
New Jersey
You may be able to find an exhaust ****** gasket in the right size.
WileE7
WileE7
its a ball and socket set up where can i find a gasket
BroncoJoe19
New Jersey
That picture I got from autozone, it is for an old VW Beetle.
Maybe at a midas muffler shop, or a Napa auto parts store.
Maybe where you purchased the headers?
Call around, explain your needs.
Good luck
joe
WileE7
WileE7
Good luck
joe
everyplace that i called told me for the setup i have there is no gasket i used a sprite can and some aluminum tape and its working for now anyone have a better or permanent fix for me?
What brand of header did you buy ? A number of header mfg's offer ball & socket joints that can be clamped or welded to the collector and you then attach the Y-pipe to *that*. Outside of that I'd do what Joe mentioned and just take it to an exhaust shop. You probably need to extend or shorten the length of the header/collector combo until it mates up flush with the ball & socket and you can either do this yourself of have a shop do it for you.
WileE7
WileE7
They are summit hearders i bought from summit racing http://store.summitracing.com/partdetail.a...8680+4294907043
they are supposed to bolt to the y pipe but i'll see waht an exhaust shop can do
bidibronco
Norfolk Va
I have those same style headers and don't have any problem with them. Is your exhaust hung up somewhere not allowing it to come all the way up? I would but a little jack under the exhaust where the O2 is and give it a little help. I did have a problem when I pulled my engine out (all times but got smareter after the first) and the exhaust like to "squeeze" on the engine. Maybe you could even unbolt the headers from the engine, hook them up to the rest of the exhaust and kind of "force" them back where they need to be. I ended up using a pry bar when I did my exhaust.
