yo Dennis,
I understand on being retired..
Also, I assumed that the P1728 is the only Code; if Not, let me know.
See this
96 Bronco-F-Series Workshop Manual (PARTIAL)
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
I went through a lot of the
Section 07-01A: Transmission, Automatic, E4OD
DIAGNOSIS AND TESTING
Diagnosis by Symptoms and didn't see anything other than what was advised in the TSB:
Shift Concerns, •Feel Concerns
Harsh (Some/All)
Torque Converter Clutch Operation Concerns
•Cycling/Shudder/Chatter
242 — ELECTRICAL ROUTINE
Powertrain Control System
•Electrical inputs/outputs, vehicle harnesses, powertrain control module, torque converter solenoid, transmission range (TR) sensor, brake on/off switch, throttle position sensor
•Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Perform Torque Converter Engagement Test and Pinpoint Tests C and D using Rotunda Transmission Tester 007-00085, Cable and Overlay 007-00107 and the Transmission Range (TR) Sensor Cable "B" (MLPS Manual Lever Position Sensor Cable) 007-00086 or equivalents as outlined in this section. Clear codes, road test and rerun On-Board Diagnostics.
Speed Control Equipped Vehicles NOTE: Refer to Routine No. 212 before you proceed to No. 342.
342 — HYDRAULIC/MECHANICAL ROUTINE
Fluid Condition •Inspect fluid condition. If burnt or contaminated drain fluid from the transmission assembly and converter assembly. Check control attaching bolts for proper torque. Retighten as required. Record and erase On-Board Diagnostics codes. Bring vehicle to normal operating temperature. Perform Transmission Drive Cycle
http://www.diesel-dave.com/vehic/manual/stj/stj71a15.htm#extract_1016
as outlined in this section. Perform On-Board Diagnostics. If condition still exists, continue diagnosis.
Main Controls (Valve Body)
•Bolts not tightened to specification
•Retighten bolts to specification.
•Torque converter clutch solenoid malfunction
•Refer to Electrical Routine No. 242.
•Gaskets damaged
•Inspect for damage and replace.
Pump Assembly
•Cross leaks
•Inspect for porosity/leaks, valve damage; replace pump as required.
•Gaskets damaged
•Converter clutch regulator valve damaged
•Inspect for damage. Service as required.
Stator Support
•Teflon® seal on nose of stator damaged, cut, leaking
Torque Converter Assembly
•End play (excessive), internal leakage
•Inspect according to procedures outlined in this section. Service as required.
