95 302
Six litre tune-up, msd coil, cap and rotor
ford 9mm racing wires
Shorty headers, dual exhaust 2.25"
flowmaster series 40
10 degrees timing for now
cleaned intake manifold, removed egr valve and thermactor system along with air pump
Where to now? I smell the engine running rich. On cold nights she roars like a champ. Hot days, a little sluggish.
There is a lull between 1800 - 2500 rpms, then she blasts off
I knew adding headers would add grunt and horsepower, but she will never be fast (6000lbs!)
I want more torque and bottom end.
Is a cam the next step? Is there any steps in between I should try? Was thinking about a KN cold air kit and filter.
I only have one oxygen sensor (obd 1 1995 (built 8/94)), should there be two? I didn't see any connectors when I was under her last.
Any suggestions?
Any suggestions?
