Engine block question
ProPain
Bristol, VA
I dont know anything about engine block codes i know its a 351W and the serial number is E4AE-6015-FA17 is there a way to tell from the serial number if this will work in a 94 bronco.
The first letter of he code is the decade ( E = 1980 ), the second number is the year (1984). the 3rd letter is the car/ truck models that the engine originally came in or was desgnated to, like a Ford Galaxy or whatever. The 4th letter is part code (E=Engine). JSM84
http://raceabilene.com/kelly/hotrod/engine4.html
Will it work in a 94 Bronco? You can use the block, and use fuel-injected heads & intake instead of the carbed ones that were on it original. But I would look for a newer engine for the 94 Bronco.
ProPain
ProPain
Bristol, VA
that helps a bunch thanks i may go ahead and get the block dont really need it but i may get me a project bronco and throw it in that
digs
