drivers side arm rest
Devil Dog08
philadelphia pa
how do you repair the arm rest .the drivers side goes all the way down .it seem the part that stops the arm in a level position snapped off on the inside. any ideas maybe like a ***** where the stopuse tpo be?
Sorry for the delay.. Comcast likes pre 1992 Conn Speeds here;
Arm Rest Repairs/Mods Source: by Billingslee (Bronco Bill) at SuperMotors.net
It appears to be = to your problem
Bill wrote elsewhere;
"...so recently my passenger side arm rest suffered some carnage when a fat kid leaned on it...
went to 3 junk yards in search of the right one but all of the bronco were of the wrong year. So i decided to deal with what they were givin me and take one out of a 90 or 91 and of course it was to tall and a different shape, so i clamped them together and trimed the fatty using the old one as a template.
I used the pieces of foam i shaved off to fill in where it was short
then i used 3M super stregnth spray on shit to glue them on the back
Next i taped the **** out of it to smooth out the edges and get the angles from the old one i needed."
Same too: Repairs in a 94 Source: by R94broncoXTL (Ryan) at SuperMotors.net
Let us know if this is what you need.
GL!
broncomudder707
you should look at the arm rest for a zipper. if it has one, unzip it and pull the cover back. tighten the bolt that attaches the arm rest to the seat while looking for proper movement of the arm rest. hopefully that will fix your problem!! good luck!
digs
