92bronco_in_progress
Yeah its a 92 bronco
just brainstorming, and i thought i would throw this out there.......it could be the ignition control module on the distributor
thanks for the ideas. I edited the original post to say that i changed the ICM recently.just brainstorming, and i thought i would throw this out there.......it could be the ignition control module on the distributor
I'm still waiting on my girlfriend to stop being a pain and help me with inspecting the distributor. I cant start it and take the dizzy cap off and look inside by myself. I'll try to search for more info on this pin you speak of in the mean time.I think that there is something wrong in that if he has spark at the coil like he says, but not out of the distributor that means the the hall effect pickup coil is working, so is the EFI module. The problem is somewhere between the coil wire, the cap to the rotor connection and then the rotor to cap gap, through each of the eight wires to each of the eight plugs.
I recall shift1313 speaking of a pin inside the dizzy that breaks or comes loose or something, and when that happens the rotor does not turn. What I don;t know is... does that pin only affect the rotor? OR does it affect the spindle that interacts with the pick up coil inside the dizzy too?
I guess we'll know soon.
