Cruise control Gremlin
96Br0nc0Guy
San Antonio,TX
96 E.B.
Cruise works normally until...
You turn on either parking or head lights then cruise shuts off. Turn lights off, cruise works again.
How are these two system interrelated? Where should I be looking to troubleshoot?
Thanks!
L\Bronco
A.B. Canada
96 E.B.
Thanks!
Hey Broncoguy!
On a 96, part of the cruise circuits ground through the brakelights. When the brakelights activate, the ground goes away and the cruise cancels.
A bad ground at either of the tail lights will recreate this scenario as soon as the park ligkts come on.
So, long story short, look for a bad ground at either tailight.
Hope that helps.
Cheers!
Or a busted bulb filament. They can break and short across.
But yes, brakes lights is where to look.
goffprof
CT
The cruise on my ‘96 EB Bronco just failed. Brake lights work, 3rd light works. Will LED bulbs in the brake lights affect it due to the low current draw? The 3rd light has regular bulbs.
LED should not affect the Cruise control.
Has your bronco ever had the recall done for the switch on the Master cylinder? There could be a failure there causing the Cruise to fail.
Jimbo26
Texas
Hey L & Tiha, a question about a generic issue I seem to have identified on these older F-series chassis-
I've noticed that when cruising down the hwy, if the 4-way/hazard lights are activated then the auto trans will downshift/unlock.
Always struck me as a odd sort of glitch to have and every single older F-series with a auto trans that I've driven does this.
Cause?
L\Bronco
A.B. Canada
Cause?
Hey Jimbo, the hazard/sig lamps are the same filament in the taillights as the brake lights. When the hazards are on 12v will back-feed to the brake switch. This circuit is also ran to the pcm. When the pcm sees 12-14v on this line, the T/C is unlocked as it appears that the brakes are applied.
Hope that helps
Jimbo26
Texas
Groovy,
Not the 1st time I've heard of a LED be a issue on a older system.
Hey 96B, does your rig already have the 3G alternator?
(Thats one upgrade ahead on mine) Curious if a higher amp output there is what the LEDs like to see. 🤷‍♂️
Something tells me we may get a lesson in Ohms law after saying that, but a refresher is ok.
Appreciate the feedback on that downshift issue, L.
I knew it had to be something like that, for the entire series to have the glitch.
Will have to ponder and see if there is a diode/ ⚡️filter type thing-a-ma-jig that can eliminate that issue, even if it's not a real concern.
Still, that's a demerit on a cheesy electrical engineer way back when for not catching that! 😏
goffprof
CT
I reinstalled regular bulbs in my 3rd light but no change to my dead cruise. Brake lights work fine, so I’ll troubleshoot it when the weather is warmer.
