Check Engine Light / How to check codes
VAMUDHOG
Hampton, Va
In advance thanks for the help. I'm new to Broncos. I just picked up this 1995 Bronco with a 302. It came with paperwork showing that there is a new long block in the truck with less than 25k on it. I get this check engine light that comes on after the truck warms up. I was wondering how to check the check engine light to see what codes it is throwing. I know with the old dodges you filt the key on and off three times and than count the blinks. If somebody could tell me how to check this bronco and has a list of all the codes and there meaning or a web site that would be quite helpful.
Our friend Bronco Joe has a great description of how to check for codes. I'd normally post it but can't copy threads at this time. Just use the key words "code reader" in the search and you'll find several threads with his info. There's also a link to a list of the codes in the How-To & Tech froum, as well as on Miesk5's Homepage of Bronco links, JSM84
This one may work:
http://www.supermotors.net/registry/media/245234
Oldhenry1
