changing rear end gears
95 full size bronco
ok here we go.. i have a stock 1995 full size ford bronco with 351 all stock from head to toe.. now im fixing to add 6 in lift and 3 in body with 35x12.50x20 tires and wheels. so QUESTION IS what kind of gears should i change the rear end too???? any answers anyone.. thankssss
lobo1117
Upstate SC
First, you need to match both the front AND rear
gear ratios.. that being said, with your mods,
4.10s would be a good choice for a d/d and allow
limited off roading....
wileec
Erie CO
With 35s I would go 4.56 I have that with 32s and love it, but I also have a 5 speed. You do need to match the fromnt and back you can not do just one if you ever want to put it in 4WD. You can do 1 at a time but I would remove the front drive shaft so you do not accidently try 4WD 3.55 front and 4.xx rear WILL break something.
digs
