johnnyreb
Yesterday I was tinkering on my old 64 Ford pick. It would,nt start. So I started and check to make sure all the electrical was doing their part.Which it was. Then I checked it was getting gas-it wasn,t. I took out the jets and took so fine wire out of a wire brusk and got some cleaned out,but gas would not go through. So I thought I would try something different. I took a bottle of Star Tron. I cleaned out all the gas from the fuel bowl and filled it up with Star Tron Enzyme (you can get it at Lowe,s or at a parts store. I checked it this morning and some fluid did go down. I pushed on the gas linkage and gas came out reaal good on 1 side and a little on the other. I works better the carb cleaner and alot cleaner
