Can't find master cylinder fitting
FMyers
Just got my 1985 bronco it has the 4.9l and a 4spd manual, and am new to site. I have been trying to completely overhaul this beast by winter get it great running shape then do cosmetics in the summer definitely running out of time but most is done however after completely doing most braking components (booster,cylinder,calipers,pads,wheelcylinders,springs,lines) i cant seem to find the smaller master cylinder fitting if anyone has the size or what i need to ask for it would be great thanks and also the bigger one all though its not needed probobly better replacing that too.
Welcome to the Zone > . Are you talking about the lines from the Master Cylinder to the Proportioning valve? Also, did you bleed the Master cylinder?
F
FMyers
thank you but i actually ended up getting everything brakes work great, well as good as they should lol. the only problem i had was the hose that split the rear that was welded on the axle was shot so thankfully a local napa had the hose but couldnt weld the new one but its definitely not coming off!!! so brakes are great now on to the next problem.
digs
