Bronco toper.
Alex A
hello.
Does anyone have suggestions on the best way to keep the interior of a bronco clean or not disgusting when they take off the top. i want to take the top off for the summer and wanted to know if it was best to get seat covers and take out the carpet and how to keep speakers dry or if its worth it to find a topper to buy. I would like to know if anyone had ways they did it and it worked out well. please let me know your ideas and suggestions.
thanks
Friends in my parts of da pinies have found it very diff to keep the Bronco interior clean without
a garage and at least bed sheets over it for dust
animals tend to like our Bronco interiors, just as Dogs and insects do too; squirels rip em up here; they seem to enjoy the vinyl trim, seats, dash and all wiring insulation
a tarp helps for non-animal issues; I had a HD tarp suspended over the 78 for a year or two; made it look like a parachute by installing ss/or brass grommets in center and using a rope to hang it from a tree branch.
ez tp drop and spread over with reope lengths in 4 corner grommets.
much ezier that a car cover that hangs up on everythAng
Soft Top Sources;
I wrote it up recently here @ http://broncozone.com/topic/21648-soft-tops/page__gopid__113283#entry113283
go there for the Hot Links.
==== If you want it to be fairly clean and dry during trail or beach adventures;
Make or buy Neoprene or Vinyl seat Covers
Wet Okole - Bronco/Ford truck seat covers (neoprene & nylon)
Consider vinyl covers w/out ventilation inserts, such as by our Sponsor here, Jeff's Bronco Graveyard
Item #37503DB - New
1980-86 Bronco
High Back Vinyl Seat Covers
Dark Blue
http://broncograveyard.com/bronco/c-202-seats.html
These are Vinyl High Back Seat Covers For The Front 2 Seats only.
Smooth on the sides and pleated in the center. $250.00
Or just use velcro and buy vinyl from Wal Mart and diy wrap; I really use a lot of "industrial strength" Velcro from Wal Mart to secure plastic/vinyl and hang things in the Bronco. Good too for soda can insulator attachement to seat belt reel @ B pillar trim
do dash too and have it drape down over instr panel; I used to have a pic of the 78 with the vinyl along dash, rolled-up tightly against windshield (held it to dash pad by pulling pad up and having vinyl wrapped under pad) and we un-rolled it if it rained so it came down over inst panel protecting gauages, switches, trim.
Pad pulled pic by grover in his 78:
Could do same for speaker grilles...using 3M HD command strips t hold vinyl pieces over grilles; remove when not needed
I have the rubber/vinyl mat instead of carpeting in my 96XL; in fact, I chose the XL when buying it new over the Sport/ XLT/EB models (was foaming at mouth over the Sport Model) bec. we do a lot of surf fishing & over the sand runs and carpeting makes life miserable here as well as our sandy soil, pine needles, etc.
It is not water-proof, but I used black GE RTV sealant along seams/non door sill joints, around side panel trim, B pillar (have to keep the connectors dry on both sides; esp air bagged Broncos where safing sensor is inside B pillar trim on passenger side..
etc.
digs
