Bronco Help
78BroncoCustom
Memphis, TN
I have a 1978 Ford Bronco Custom an I have been trying to find out if i could fit 35 under a 4" lift an I cant find any lift and tires sizes
can anyone help me out?
Can I fit 35s under a 4" lift?
Fritz180
Fairfield, New Jersey
what size 35s are you thinking about putting on. I haven't tried it yet, but I'm going to be putting on 35x12.5R15 and I don't think I'll have any issues from what I read and asked other people about. The only thing they did say was that it may hit the bottom edge of the fender. hope that helps
JCFindley
Kansas City
35" should fit without any modification.
OK, perhaps I am just loony, or my ex spiked my coffee with drugs but 35s would only work unmodified IF you had real skinny 35s and drove only in a straight line.......
I ran a 4 inch lift on my 79 with 35x15.50-15LT Swamper TSL SX's. They would rub slightly when the truck was flexing hard and in a turn. Other than that I had no issues with 4 inches and 35s. The 15.5 in SXs have a 13.1 inch tread width which is pretty wide for a 35 so you should have no problems with anything that size or less.
JC
rednck7736
rednck7736
Mississippi
I ran 35x12.50x 15 on my 77 F-150 with only a 2 inch body lift which is identical to the bronco in the front end..THe only rubbing I had was when I turned sharp.They would rub the radus arm that was it.I have bottemed it out with the tires turned and never touched teh fender with it.
offroadfury
Locked And Loaded
Southeast Kansas
35-14.50 boggers on my 78 with 4" and only rub when flexing in a turn. I've seen the remedy for this which is sawzall and removing about 4" of sheet metal from the fender but I can't bring myself to do it. Fender usually curls in and is easy to pull back out.
78BroncHair
Motherlode CA
I have 35 12.50r15s on my 78 bronco with a 4 inch lift on it. No body lift. You may have to try an odd backspacing on your rims though. I cant remember what mine are.
david@holycitytransportat
