brakes
jehusafat
i have an 89 4.9l i6 fuel injected bronco i have been having repeat problems withmy brakes every time i have replaced the calipers and pads after a couple months of driving they giveout the caliper blows or the pads fall out on the back side of the caliper i was wondering what could be causing this i have replaced the brake booster as well as mastercylinder i was also wondering if there are any aftermarket brake systems for my bronco i have looked everywhere and can not find any thanks in advance for any help
It's hard to say without seeing them, but the only thing come to mind is that they are not installed properly. Other than that, I'd take it to a good mechanic, especially since this could result in a fatal accident either for you or someone else. How much is your life worth?
J
jehusafat
do you have any idea where to get any aftermarket parts and i have had the brakes and everything done about a year ago at desert rat the only true off road place here in nm
digs
