Brake bleeding
cav
Utah
Really dumb question.......I am trying to bleed the brakes on my '89 Bronco. Was able to do the back ones-but-when I moved to the front ones the bleeder tool would not fit--to small. I have tried every size the stores have, even metric but can't find on that will fit properly. The fittings are not damaged and I have tried both sides. Not sure what else to try short of using a set of vise grips on them..any suggestions ? Thanks.
Bronc76
Can you try to measure the fittings with a set of caliphers or micrometers to determine the size? Has the area been cleaned and free of possible dirt and debris?
cav
cav
Utah
if all else fails use the vise grips then by a new set of bleeders. have you tried line wrenches?
Looks like the "grips" might be the way to go, then I can get a set of bleeders that fit the wrench before I install them....Thanks much!
The front bleeder screws will often require the Vise-Grips anyway. I had to replace both sides up front on my 88 axle. Took a few hours and some choice words to get them loose.
cav
cav
Utah
Hey Shooter, I got the vice grips, could you help me out with a few of the "proper" words? None I know seem to work. :D /emoticons/[email protected] 2x" width="20" height="20" />
SURE. I even welded a nut on the end of one, hoping the electricity would loosen the rust and using a big wrench would help. That didn't work, darnit!!! Typical of many Ford parts, the metal on the bleeder srews is soft, and even if you have the propere-size wrench, the hexhead of the ***** will strip out or round off. Fudge!!! There's very little room to get a good bite of the Vise-Grip pliers, then there's even less to try and turn it. A BFH was used to tap the V-G pliers and break the bleeder ***** loose, after several failed attempts.What did finally help was advice from my Dad. Take that hammer and hit a few taps on the top of the blleder *****. It will booger it up on top, but will break the bond of the rust and corrosion. There were a few "freakin'" phrases in there ,too... You would think I spent 22 years in the Navy. JSM84
cav
cav
Utah
Now I know the problem I've been a civilian to long-22 years in the Army. I'll dig out my "Phrase For Every Occasion" Army Field Manual, it always worked on M1A1 tanks.
digs
