Hey bud, you're not wrong or I don't argue with what you state.You make some great points about the virtues of your soilid -axle Bronco. I would have prefered to do an SAS on my Bronco instead of the 6"lift on the stock suspension. I know from experience that at some point in the not-too-distant future that I will be replacing an axleshaft or u-joint in the front end. I'll be breaking the rear 9" parts sooner if I install a minispool for better ttraction. That's when I will upgrade to an axle set-up from an F250 to get stronger components that can better handle the 35" tires. >-
