sreaminbronco
Which company has the biggest suspension lift for the bronco? I have seen 8in. @-) but thats the highest i have seen. I was just wondering if there was bigger?
Nah, their all full length. But big tires are gonna stick out far. With the stock TTB front end you can only run probably 38's safely, plus TTB is a pain in the neck to align, and prob. won't with that much lift. If your serious about that big of a lift and big tires i would def. swap in a new front axle. a Dana 44 or a Dana 60 would be better. You should probably swap the rear to a 1 ton axle as well, so its not tempted to break. Its a lot of work.are the axles any longer than whats on a 92' bronco because if so the with the width of the tire and the legth of the axle youd have to install cameras so you dont run over a can or scrape a mud wall.
16617[/snapback]
