Back Passenger Seat Removal
Dagger_91Beast
Dallas, Texas
Quick newbie question. Was trying to take the back passenger seat out of the Bronco yesterday. Pulled the lever and lifted the seat, but it looked like I had to remove cotter pins and retaining bolts to lift the seat out. Is this correct?
C5aig
Pull the cotter pins on the outside and the lever in themiddle and the seat should come out.
Roadkill
Killeen, TX
It's as simple as it looks. Remove the hinge pins and torsion bar and out it comes. The torsion bar may not be present if a previous owner removed it and didn't put it back.
Install the seat and lift it to the 90° position. there are places on both brackets for the bar to slide into and rest. you know that you have it in correctly when its putting pressure on the bench
testtesttest
