And the question is ?
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
/emoticons/
[email protected] 2x" width="20" height="20" />
The short answer is that the tag just indicates that the axle has an open differential and a 3.5 to 1 ratio as opposed to something like 3.08 or 4.11
As far as the specifics of the tag go, well, that's more complicated. The 610185-10 is the "bill of materials" and is the number you'd use to look it up in the Spicer/Dana catalog. I've attached a copy of the catalog if you or anyone else is interested in it (great diagrams and parts info for Dana/Spicer axles). Basically what it says is that the 610185-10 was installed in 81' & 82' Bronco's & F150's. It's a standard (open) differential w/3.50 gears. From the Bill of Materials # you determine which kits you need for the ring & pinion, case assembly, inner parts, etc.
The E1TA is a partial Ford part #, specifically it's a prefix used with truck drive train components (axles, drive shafts, transfer cases, etc). I *know* it's a truck prefix used for early 80's trucks. Just what years it was used during and what models it covers escapes me, maybe someone else knows or can shed more light on it.
X510_9.pdf
