yo Carpenter,
WELCOME!
Try this Operational Test;
Remember to block the wheels.
This would work for testing manual hubs too, just lock them 1st;
"...Place transfercase in 2HI or Neutrall.
2. Lying under vehicle, turn front drive shaft (one direction only).
3. Automatic hubs should lock after 1 to 5 turns of driveshaft (one direction only). After step 3 the hubs should lock, youll know they are locked becouse you will hear a click from both hubs and you will no longer be able to turn the front drive shaft (in the same direction). If this is not the case then continue to step 4. If you can no longer turn the drive shaft (in the same direction) then skip to step 7.
4. If you can still turn the drive shaft (one direction only) then one or more of your Auto hubs is not working.
5. Continuing to turn the Drive shaft (one direction only).
6. Look at the u-joints for the front stub axles, if both are turning then both front hubs are malfunctioning, if only one is turning then the one that is not turning is locked and the one turning is malfuctioning. Replace as necosary (preferably with manual hubs, Auto hubs have Yams in them)
7. To unlock the hubs, turn drive shaft in opposite direction until you hear a click from the hubs.
To check for transfer case engagement.
1. Place pushbutton transfercase in either 4 HI or 4LO.
2. lie under vehicle.
3. You should not be able to turn front drive-shaft in either direction.
4. If you can turn the front drive shaft then your transfer case is not shifting properly..."
Source: by Gacknar
Do you have the AOD or E4OD trans?
E4OD, AOD & C6 Pan Identification & Driver Side pics by Kenneth. Shift Indicator Patterns & Indicator pics (AOD, C6 & E4OD); AOD have 14 pan bolts, P-R-N-(D)-D-1 shifter pattern, note, OD is actually a (D) - pic by trigger; C6 have 17 pan bolts, P-R-N-D-2-1, shifter indicator pattern - pic by miesk5; E4OD have 20 pan bolts; P-R-N-D-2-1 shifter shifter indicator pattern - pic by Chris A.
Source: by miesk5 at Ford Bronco Zone Forums
http://broncozone.com/topic/22732-1990-bronco-351/
Four Wheel Drive (4X4) General Information, Operation & Troubleshooting TSB 92-1-8 for Bronco, F Series & Ranger (COMPLETE); Includes Electric Shift On The Fly (ESOF) Troubleshooting & Hub Operation; same for 87-96Source: by Ford via Chilton
http://content.chiltonsonline.com/TSB/displayTSBHandler.ashx?assetID=36059&key=6kAUBD5BruOJf%2f3tgozUqjXM3RdbjcQqW4sVWiE%2fp2IojfpfKqM07dr61%2bQAWHtTZr4ceHaQGlj8NylACcNZ4qedMqy4JdYyAXN5akgfkpHUz4aCpJyaaA%3d%3d
Is Check Engine Light (CEL) on all the time?
Check Engine Light (CEL) comes on when the electronic engine control system is not working properly. The check engine warning indicator comes on briefly when the ignition switch lock cylinder is turned to ON, and should turn off when the engine starts. If the check engine warning indicator does not come on when the ignition switch lock cylinder is turned to ON or if it comes on while the vehicle is moving, the system is malfunctioning
If the CEL does not light up at all when starting it; then suspect that someone removed it.
If you have not heard any unusual sounds from transfer case or vibes then we can iggie it and try to troubleshoot the trans or a sensor by checking for codes;
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.
Look Codes up in my broncolinks.com site using the new Search function.
And Post em here according to:
KOEO
KOER
