muddinlate86
just a little over woried that im loosing my tranny.when driving at highway speeds 45 60 mph my tranny "slips"in and out of over drive.i know my fluid is a little low so just a fill would fix it right?
Isnt that normal? Haha, my Bronco worked fine in overdrive with the stock tires but when i stepped up to 33's it wouldnt accelerate in 4th gear, it would pull all the way up through third then when it shifted into overdrive it would slow down causing it to shift back down to 3rd. Seeing that you have 35's that might be the same thing. For you to correct this you will need to get lower gears, 4.56 works great with 35's. Thats my opinion anyhow.just a little over woried that im loosing my tranny.when driving at highway speeds 45 60 mph my tranny "slips"in and out of over drive.i know my fluid is a little low so just a fill would fix it right?
