Yo ski,
As Seabronc advised and I have been collecting info in event I need a swap in our 96...here is a summary:
"...I have a set of leather buckets out of a Suburban and they seem a bit wider and fairly comfortable. Re-used the floor plate bracket and mounted the seats to a set of flat bars that then bolted to the floor bracket. That was for the powered driver seat, the other 3 new mounting holes in the seat rails and they bolted up to the floor mount bracket..."
Installation Info (1999 F 150) buckets in an 88; "...I had to drill new holes in the stock bronco brackets to accomodate the studs from the f-150 seats. I also had to drill 2 new holes in the floor because the f-150 slider brackets are further apart about 1".. It worked out ok because there is a little reinforcement panel underneath the bronco body and you still hit it when re-drilling. For the passenger side, I added some angle iron to the bronco flip-seat bracket to get my extra width I needed, pretty simple actually..."
More at my archived site
https://web.archive.org/web/20101224175040/http://www.broncolinks.com/index.php?index=312
Read my signature on seeing current url
