69bronco69
hey guys - more problems need some help
Few days ago had a dead battery. Tested at 11.4 volts. Took it to NAPA - they said a bad cell. Put in new battery. Within a week - dead battery.
Here is what I did:
1. Cleaned battery terminals and posts
2. Charged battery and then test battery across post - got 12.4 volts
3. Started engine and tested bettery across post - got 12.4 volts = not charging
4. Turned off Engine and removed ground cables from battery
5. Used test light from negative post to ground - test light did not come on = no battery drain
6. Reattached battery cables
7. Unplugged VR and plugged it to temp replacement VR that was grounded to negative post of battery with jumper wire/alligator clips
8. Started engine and tested battery across post - got 12.4 volts
9. Followed same process with another VR and got same results.
10. removed battery cables and alternator - noticed broken wire from stud - broken wire
11. fixed wire and reinstalled alternator and battery cables.
12. Tested with old VR and the other two VR's and got same 12.4 volts reading with engine running
13. Installed used alternator and performed tests with the same three VR's and got same 12.4 volts reading
14. I did noticed there was some corrosion on the plug that goes into the VR after all the previous steps above. One of the wires broke off from the plug at the "A" that goes into the VR. It was yellow wire plugged into same terminal of another yellow wire. It goes to the "thing" that is supposed to keep the humm sound out of the AM radio i think.
VR broken wire -VR broken wire
corroded plug - corroded plug
I borrowed the two VR's and alternator from local shade tree mechanic. He said they all worked when they were removed from other Fords.
I'm not sure how to use multimeter as to test which terminals on alternator or VR other than what I did above. I have read other threads but still dont quite get where to put the multimeter leads on which terminals to do the testing.
I thinking of getting a plug from junkyard ford to see if that is the culprit. Did I miss anything? Please Help
john
Here is what I did:
john
