alternator upgrades
90bronco86
deltona Florida
I have a lot of electrical equipment on my truck such as hid lights, air horns, aftermarket head unit and speakers and I plan on adding a light bar and doing the electric fan conversion, is the 3g alternator upgrade enough to handle this and more? Or is there something else that is better? My bronco is a 90 with a 351
yo 90,
Yes, a 3G will help a lot.
see a few 3G install Links @ http://www.broncolinks.com/index.php?index=74
there are the "normal" 130 amp 3G, 160 amp (3G) and 200 amp 3G; then there is the 220 amp, AIS Installation in a 91
Source: by Eric L (The Rig, SOLD) at http://supermotors.net/site/erlong/progressive/051999/alternator/index.html
When you swap from a 1G or a low output 3G to a 130 or more amp 3G, although you do not NEED a larger charge cable such as a 2 Gauge, it is a great idea. Smaller wires/cables cannot always handle such a load and they tend to heat up, some to the point of melting the wire and could start a fire. ALWAYS make sure you use a megafuse rated at least 15-25 amps above your alternator amperage.
Also see Alternator Files
http://oldfuelinjection.com/?p=63
by Ryan M (Fireguy50)
GL!
90bronco86
deltona Florida
yo 90,
GL!
Well that seems easy enough, where can I get the 220 amp alt? Is there a car that came with it or do I have to buy it new?
yo, Many stores sell them esp our SPONSOR, Jeff's Bronco Graveyard
http://broncograveyard.com/bronco?search=alternator
see up to 250 amp units
High Output Alternator, 250 Amp, Serpentine Pulley # 38614B
New
1986-92 Ford Bronco
1986-92 Ford F150, F250, F350
Stock Plug
100% new high amp components
302,351W Small Case (7") Serpentine Pulley
Price: $359.00
So is there a car I could pull one of those alternators off of?
yo 90,
I have no info on that other than asking at a local no pick n pull yard;
; For a YARD SEARCH on-line, I use;
http://www.mypartshop.com/
Select All Parts
1996
FORD TRUCK
F350
Alternator
State
diesel 215 amp
saw no 250 amp alts
also, READ this 3G Interchange Facts
Source: by Clarko (B-Ronk, Brian C)
Bebop Man
Rapid City, SD
220 is huge, possibly even overkill.
I've got a 165a 3g, and I run a 12,000 winch, OBA, and 810 watts of lighting. Under full load, lights,. winch everything, the system voltage only drops to about 13v.
$190 to RJM for the alternator, 3G harness, and charge cable made for a pretty good deal for me. If you looked hard, I suppose you could find a similar kit on e-bay, too
90bronco86
deltona Florida
I just don't want the same problem I have, when i hit my air horns with my hid lights on the truck almost stalls and my volt meter just plumits.
See this info from RJM food for thought http://www.rjminject...0amp-alternator .
Those two items may load down your current alternator, which in turn loads down the engine, but a 130 - 160 should not have a problem.
Also do the wire from alternator to battery and voltage distribution point. (see kits at RJM) . If you don't, putting a larger alternator is pointless and the old wiring can not safely support the increased capability.
BobButtertone
