Actuator rod
BRONCOKID88
Cowpens, SC
My actuator rod dislocate from the steering column, I found a post a few weeks ago talking about a joint that came loose from the steering column. Does anyone know about this, or why I can find the joint? For the moment I installed a push button, but i want to be able to crank her right again.
Thanks,
Mitch
If ther Actuator rod is not broken, then the most likely thing is that the link that connects it to the keyswitch is broken. The link is different for a non-tilt and tilt column. In anyy event you have a bit of disassembly and reassembly ahead of you to replace it.
Get yourself a Haynes, Chiltone or better yet a shop manual. If all else you can take it to the dealer.
wrachet
Kansas City Area
The actuator rod can be a pain in the butt! Do you know what cause it to dislocate in the first place??
Colleen
Colleen
29924[/snapback]
Unfortunately the link that connects it to the key tumbler is the weak link :-& .
wrachet
Kansas City Area
30048[/snapback]
That's what I was thinking. It took us forever to get everything lined backup when we replaced the ignition switch module and all the other stuff in the steering column!
Colleen
Colleen
30082[/snapback]
There is a proceedure that makes the alignment easier, but just getting at the link to replace it requires a lot of disassembly and re assembly.
wrachet
Kansas City Area
30088[/snapback]
Oh now you tell me!!! LOL...
After everything that I went through with the Bronco and the actuator rod...I think I could probably consider myself a professional at taking that thing apart and putting it back together.
:) /emoticons/[email protected] 2x" width="20" height="20" />
Colleen
BRONCOKID88
BRONCOKID88
Cowpens, SC
I think I might just leave the push button I have on it now on there for a little while longer. I just dont feel like taking the steering column apart anytime soon. And it came apart when I ran the Bronco into some trees beside a lake...long story. but she managed to make it out with only minor damage.
Mitch
Savage, Minnesota
I think I might just leave the push button I have on it now on there for a little while longer.  I just dont feel like taking the steering column apart anytime soon.  And it came apart when I ran the Bronco into some trees beside a lake...long story.  but she managed to make it out with only minor damage.                      Mitch
30437[/snapback]
um......... okay.
the link to the tumbler is weak. it is pretty bad so actuator rods are not uncommon to dislocate. :)>-
wrachet
Kansas City Area
um......... okay.the link to the tumbler is weak.  it is pretty bad so actuator rods are not uncommon to dislocate. :)>-
30439[/snapback]
I found that putting the actuator rod back on was a pain. I would get it on, put it all back together...and then find out it had slipped off again. Frustrating...but finally found a way! Sometimes it is nice to have skinny fingers!!!
It can be done without any special tools but it's a pain.
Colleen
Savage, Minnesota
Colleen
30473[/snapback]
pain in the ass i've heard. glad ya got it back in! :)>-
lesbeauty89
bronco queen
okay, i am like new here, so don't give me a hard time if i sound a little dum. lol. i was just wondering what an actuator rod is and does? lol. i am just a 19 year old blonde girl, lol. i do own an 82. ttyl! 0:)
Savage, Minnesota
30481[/snapback]
uuuuhhhhhhhh........
you own an 89 there katie.
The actuator roc is a stiff wire rod that connects the key tumbler to the start switch on top of the steering column.
lesbeauty89
bronco queen
30571[/snapback]
As you can tell, I am not that "car smart". I get BroncomaticMinnesota to do all the work on my bronco. lol. my dad isn't really ever around so BroncomaticMinnesota helps out with truck work. My mom is always at work or dating. so we have lots of parties. :)>-
Savage, Minnesota
30574[/snapback]
you actually had your actuator rod pop off of yours. remember me and your dad worked on it. he was the one who put it back in though. he didnt want me puttin it in the wrong place. but that was the first time i actually worked with an actuator rod so it was neat to learn. your dad is a good guy. ya just gotta be on his good side.
wrachet
Kansas City Area
30478[/snapback]
Yeah the only problem I'm having with that part of the vehicle now is that I have to sometimes lift up on the steering wheel to get it to engage the ignition switch module... :) /emoticons/[email protected] 2x" width="20" height="20" /> Easy fix though...just have to get around to doing it.
Colleen
Ford644
