9in litf radius arm problems
BigRed79
clinton ky
I finally got my first project 79 bronco started. Ive got 9in lift coils under the front end and before i did any research i fabbed up a set of radius arm drop brackets which upon putting them on i realized were way to low and i would have major ground clearance issues. So i was wondering about what size my drop brackets should be wit how big of a degree c bushing for a 9in lift
muddrivermike
Texas Arp
Same here,MY 78 bronco has 9in of lift and my arms are also level.Thats the way they are suppossed to be otherwise you'll throw you caster way out,and they only make the C bushings up to so many degrees to compensate :D /emoticons/[email protected] 2x" width="20" height="20" />
79brnco
