Good stuff;
Have you tested @ motor for power w/either key of drivers switch engaged? And pushed ******* tg driver side high to ensure latch safety switch is engaged?
Here is Steve83's tg tech Link that includes all of what the Bronco brothers advised:
Motor Replacement; "...If the motor runs but doesn't move the glass, push the glass up for access. The glass is strong enough to support its own weight fully extended, but no extra weight..."
by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/vehicles/registry/2742/12689
miesk5 note,
I got in the back and removed tg access panel as you prod did to apply 12 v from a cordless drill battery or use jumpers from another batty to test motor @ motor connector. To raise glass I used a small suction cup like a toilet plunger to inch the glass up from inside far enough to get to it by hand outside.
Tooluxe 4-3/4 Inch Single Handle Suction Cup for Glass $6.99 @ SEARS..I think they have a smaller size too that comes as a kit of 2 for almost same $
http://c.shld.net/rpx/i/s/pi/mp/7840/2049985501p?src=http%3A%2F%2Fwww.etoolscity.com%2Fproducts%2FNeiko%2FR53711L.jpg&d=212e8c64254931a08978365463bac2c4f802e746
I use a standard height saw horse with a blanket folded to support da glass.. make sure the tailgate is resting DOWN fully (horizontally) by pushing or sitting on it before pulling glass out by hand (or closing driver side Latch by hand and using Key sw or driver's Dash switch to energize motor) and sliding saw horse under da glass...the cables need to fully stretched...
& in his #7; "If the motor doesn't run, remove the 4 nuts (2 on each side - see below) that hold the regulator tracks to the glass brackets. Bend the regulator arms down slightly to pull the studs out of the brackets, and then push the glass up. Remember to FULLY lower the glass before lifting or closing the t/g..."
Glass Replacement & Parts Break-Out Diagram in a 96 from 1996 Bronco Workshop Manual;
"...Open tailgate. Remove inside cover access panel and retaining screws. Remove inside cover panel support and retaining screws. Remove inside cover watershield. Manually close both tailgate latches and raise the tailgate glass. Remove four nuts retaining tailgate back window glass (42006) and back window glass bracket (422B18) to back window regulator. If tailgate has heated glass option, disconnect two terminals (driver's side). Grind off four rivets, two on each back window glass bracket to tailgate glass. Punch out four rivets and remove four door window glass channel bracket retainers (234A46) and door window glass bracket spacers (234A44). Remove screws and pull out tailgate upper corner seal assemblies, one on each side. Snap out inside and outside tailgate weatherstrips with tool. Slide tailgate back window glass out from tailgate assembly. Installation, Slide glass midway into tailgate assembly. Connect heated glass wires, if equipped. Install back window glass bracket C-channels onto the tailgate window regulator arm slide guides. Position tailgate back window glass over back window glass bracket C-channel studs and install four door window glass bracket spacers, door window glass channel bracket retainers and rivets. Lower tailgate back window glass to connect heated glass wiring terminals. Close tailgate and cycle tailgate back window glass to ensure smooth operation. Install watershield. Install inside cover panel support (one *****). Install ten inside cover access panel screws. Close door and cycle tailgate back window glass to ensure proper function..."
http://www.thedieselstop.com/faq/9497faq/maint/stj/images/n8411c.gif
Item Part Number Description
1 41610 Outside Weatherstrip, Tailgate
2 23394 Window Regulator Electric Drive
3 380642-S ****** Outside Weatherstrip-to-Tailgate
4 42072 Inside Weatherstrip, Tailgate
5 40700 Tailgate
6 57472-S2 Bolt, Back Window Glass Run-to-Tailgate
7 422A20 Back Window Glass Run
8 387392-S Bumper
9 44000 Tailgate Window Regulator
10 422B18 Back Window Glass Bracket
11 57472-S2 Bolt, Tailgate Window Regulator-to-Tailgate
(4 Req'd)
12 42006 Back Window Glass
13 43505 Lock Cylinder, Tailgate
14 41616 Upper Corner Seal, Tailgate
15 376389-S ****** Tailgate Upper Corner Seal-to-Tailgate
16 14559 Clip, Window Regulator Switch Retainer
17 43629 Retainer, Tailgate Lock Cylinder
18 385323-S Rivet, Back Window Glass Bracket-to-Back Window Glass
19 234A44 Door Window Glass Bracket Spacer
20 234A46 Door Window Glass Channel Bracket Retainer
21 234A24 Window Regulator Drive Gear Kit
A — Tighten to 6-11 Nm
(53-97 Lb-Ft)
Glass Replacement in an 86
Source: by Sixlitre (Malcolm H, Eddie Bauer) at
http://www.supermotors.net/clubs/superford/registry/4970/54532
Motor Removal in a 95 = to 96
Source: by Shadofax (TheJuice, The Juice, Mark Z) at
http://www.supermotors.net/registry/628/17399
