Did you get it checked for codes for free yet?
Post any Code(S) found here
Mass Air Flow Sensor to PCM in PCM Connector Pin-Out Diagram with Circuit Functions in a 96 5.0 and 5.8 (Scroll Down) from 1996 F-150, 250, 350 (4x4), and Bronco Vehicles Workshop Manual
Source: by Ford
F-Series 5.0L and 5.8L Under 8500 Lb. GVW, and All Bronco
Pin Number Circuit Circuit Function
1 315 (P/O) PCM to Transmission Shift Solenoid No. 2
2 658 (P/LG) PCM to Check Engine Indicator Lamp
3 � Not Used
4 � Not Used
5 � Not Used
6 651 (BK/Y) Dedicated Ground
7 � Not Used
8 � Not Used
9 � Not Used
10 � Not Used
11 � Not Used
12 � Not Used
13 107 (P) PCM Flash EEPROM Power Supply
14 784 (LB/BK) 4x4 Low Range Switch to PCM Indicator Lamp
15 915 (PK/LB) J1850 Bus Negative/Data Negative (Return) to PCM
16 914 (T/O) J1850 Bus Positive/Data Positive
17 � Not Used
18 � Not Used
19 � Not Used
20 � Not Used
21 � Not Used
22 � Not Used
23 259 (O/R) Dedicated Ground to TFI Module
24 570 (BK/W) Dedicated Ground � PCM
25 875 (BK/LB) Ground Logic Module
26 � Not Used
27 237 (O/Y) PCM to Transmission Shift Solenoid No. 1
28 � Not Used
29 224 (T/W) Transmission Overdrive Cancel Switch to PCM
30 � Not Used
31 � Not Used
32 � Not Used
33 676 (PK/O) Vehicle Speed Sensor � Negative (Return) to PCM
34 � Not Used
35 392 (P/LG) Heated Exhaust Gas Oxygen Sensor No. 3 to PCM
36 968 (T/LB) Mass Airflow Return
37 923 (O/BK) Transmission Oil Temperature to PCM
38 354 (LG/R) Engine Coolant Temperature Sensor to PCM
39 743 (GY) Air Charge Temperature Sensor to PCM
40 238 (DG/Y) Fuel Pump Monitor to PCM/Fuel Pump Relay to Safety Switch
41 198 (DG/O) A/C Pressure Switch to Control Relay
42 � Not Used
43 � Not Used
44 200 (BR) PCM to Air Management No. 2 (Was TAD)
45 � Not Used
46 � Not Used
47 360 (BR/PK) PCM to Electronic Vacuum Regulator � Constant Current
48 382 (Y/BK) PCM to Test Connector No. 2
49 395 (GY/O) Profile Ignition Pickup to PCM
50 929 (PK) PCM to Spark Angle Pulse Width/Spark Output
51 570 (BK/W) Dedicated Ground � PCM
52 � Not Used
53 924 (BR/O) PCM to Transmission Coast Clutch Solenoid
54 480 (P/Y) PCM to Transmission Converter Clutch Control
55 37 (Y) Battery to Load
56 191 (LG/BK) PCM Top Vapor Management Valve � Constant Current
57 310 (Y/R) Knock Sensor No. 1 to PCM
58 679 (GY/BK) Vehicle Speed Sensor � Positive to PCM
59 917 (DG/LG) Misfire Detection Sensor � Feed
60 74 (GY/LB) Heated Exhaust Gas Oxygen Sensor No. 1 to PCM
61 � Not Used
62 � Not Used
63 � Not Used
64 199 (LB/Y) Manual Lever Position Sensor to PCM
65 352 (BR/LG) Delta Exhaust Pressure Transducer to PCM
66 � Not Used
67 � Not Used
68 � Not Used
69 � Not Used
70 190 (W/O) PCM to Air Management No. 1 (Was TAB)
71 361 ® Power Output from PCM Relay
72 561 (T/R) PCM to Fuel Injector No. 7 Cylinder
73 559 (T/BK) PCM to Fuel Injector No. 5 Cylinder
74 557 (W) PCM to Fuel Injector No. 3 Cylinder
75 555 (T) PCM to Fuel Injector No. 1 Cylinder or Bank No. 1
76 570 (BK/W) Dedicated Ground � PCM
77 570 (BK/W) Dedicated Ground � PCM
78 � Not Used
79 911 (W/LG) PCM to Output Circuit Indicator Lamp/Overdrive Cancel Indicator
80 926 (LG/O) PCM to Fuel Pump Relay Control
81 925 (W/Y) PCM to Electronic Pressure Control No. 1
82 � Not Used
83 264 (W/LB) PCM to Idle Speed Control Motor No. 1
84 136 (DB/Y) Output Shaft Speed to PCM
85 � Not Used
86 � Not Used
87 94 (R/BK) Heated Exhaust Gas Oxygen Sensor No. 2 to PCM
88 967 (LB/R) Mass Air Flow Sensor to PCM
89 355 (GY/W) Throttle Position Sensor to PCM/Diesel Fuel Injector Pump Lever Sensor
90 351 (BR/W) Power to Engine Sensors
91 359 (GY/R) Sensor Signal Return
92 511 (LG) Stoplamp (Brake On/Off) Switch to Stoplamps
93 387 (R/W) HEGO Sensor Heater Voltage Monitor No. 1 to PCM
94 388 (Y/LB) HEGO Sensor Heater Voltage Monitor No. 2 to PCM
95 389 (W/BK) HEGO Sensor Heater Voltage Monitor No. 3 to PCM
96 � Not Used
97 361 ® Power Output from PCM Relay
98 562 (LB) PCM to Fuel Injector No. 8 Cylinder
99 560 (LG/O) PCM to Fuel Injector No. 6 Cylinder
100 558 (BR/LB) PCM to Fuel Injector No. 4 Cylinder
101 556 (W) PCM to Fuel Injector No. 2 Cylinder or Bank No. 2
102 � Not Used
103 570 (BK/W) Dedicated Ground � PCM
104 � Not Used
MAF Connector Pin-Out Diagrams, pic & Air Flow Depiction
Source: by Ryan M (Fireguy50) at
http://fordfuelinjection.com/index.php?p=26
Ford Hot Wire MAF Sensor
..the MAF sensor sends either a variable voltage to the computer. The computer is programmed to accept this information when the vehicle is running in any mode. For example, idle rpm will send a low voltage and a high revving engine will send a high voltage to the computer along a specific wire (the MAF signal wire). If the signal is not present when it should be and within a programmed parameter, say high voltage at high throttle opening, the computer will set a code.
So, there are several things to consider whenever there is a code which points to the MAF sensor as the problem:
Derive the code(s) by the manufacturer's recommended method.
Look up the code(s) in a service manual
Read the explanation(s) carefully!
A code that indicates an out of range signal is
often an indication that another sensor, like the throttle position sensor is contradicting the MAF signal. The cause might be the other sensor or signal being out of adjustment or faulty.
A code that indicates a low MAF signal may be set by various problems.
These include the following:
A bad MAF sensor (internal fault)
Any wire on the MAF sensor circuit including:
The 12 volt feed wire which connects the MAF to the battery through the ignition switch
The MAF ground wire
The output wire
The MAF or computer connectors
The computer (EEC V)
I have more MAF info in my site under Fuel
EFI
MAF
such as:
MAF Servicing TSB 96-22-5 for 94-96 Source: by Ford via miesk5 at cc
an excerpt;
".... On a fully warmed up engine, look at MAF voltage at idle, in Neutral, A/C off (MAF V PID). If it's 30% greater than the nominal MAF V voltage listed in the Powertrain Control/Emissions Diagnosis (PC/ED) Diagnostic Value Reference Charts for your vehicle, or greater than 1.1 volts as a rough guide, the MAF sensor is over-estimating air flow at idle.
4. If at least two of the previous three steps are true, proceed to disconnect the MAF sensor connector. This puts the vehicle into Failure Mode and Effects Management (FMEM). In FMEM mode, air flow is inferred by using rpm and throttle position instead of reading the MAF sensor. (In addition, the BARO value is reset to a base/unlearned value.) If the lean driveability symptoms go away, the MAF sensor is probably contaminated and should be replaced. If the lean driveability symptoms do not go away, go to the PC/ED Service Manual for the appropriate diagnostics.
NOTE:
DUE TO INCREASINGLY STRINGENT EMISSION/OBDII REQUIREMENTS, IT IS POSSIBLE FOR SOME VEHICLES WITH MAF SENSOR CONTAMINATION TO SET FUEL SYSTEM DTCs AND ILLUMINATE THE MIL WITH NO DRIVEABILITY CONCERNS. DISCONNECTING THE MAF ON THESE VEHICLES WILL, THEREFORE, PRODUCE NO IMPROVEMENTS IN DRIVEABILITY. IN THESE CASES, IF THE BARO, LONGFT1, LONGFT2, AND MAF V PIDs INDICATE THAT THE MAF IS CONTAMINATED, PROCEED TO REPLACE THE MAF SENSOR.
After replacing the MAF sensor, disconnect the vehicle battery (5 minutes, minimum) to reset KAM, or on newer vehicles, use the "KAM Reset" feature on the New Generation Star (NGS) Tester and verify that the lean driveability symptoms are gone..."
