LogansLost
- Joined
- May 23, 2008
- Messages
- 5
- Reaction score
- 0
i'm trying to install a set of warn 9790 manual front hubs on my 96 stock independent front suspension bronco. i've only attempted the passenger side so far. i got the spindle nut conversion kit installed and the ****** washer set reinstalled. the only problem now is that i can't get the axle shaft far enough out of the new hub body assembly the put the axle retaining ring on. the instructions recommend using a pry bar on the knuckle to push the shaft outboard far enough (about a 1/4 in. is how far it needs to go) to install the ring. the problem is that i can't get it move even the slightest. any ideas?
