93 5.0l spout code
psychobiker
charlotte
battery died got it charged up the rough running and stalling. replace cap and rotor. then got coded for "spout" and tps and something else. took care of tps and what i thinks was the egr valve. what the heck is spout. mech said probably need new distributor. any ideas... you guys are always great
Post Codes here;
For now, Guessing that the Code is 212; if so;
Check to see if the spout connector is in place & tight
connector is a little "jumper" that fits into two wire connector; (it is removed to adjust timing).
Location pic by Ford via Jem270 http://www.supermotors.net/registry/media/465077_1
or DTC 211; "...code set when the ignition module fails, the pickup coil inside the distributor, or the engine computer. The most common of the three is the coil inside the distributor..."
Source: by RIP at justanswer.com
http://www.justanswer.com/questions/10ksv-...oaing-down-road
A possibility;
Hesitation, Stumble, Stall, Miss, No Start, No Spark and/or Diagnostic Trouble Code (DTC) 211 TSB 95-15-11 for 93-95 (Shorts in Profile Ignition Pickup (PIP) & Spark Output (SPOUT)
Source: by Ford via justanswer.com
http://ww2.justanswer.com/uploads/babarche...tion_module.pdf
P
psychobiker
charlotte
thanks but none of those show where this spout connector is a 93 5.0 ive already searched all morning
billmcg
My spout on the 89' bronc is next to the distributor, comes off the same harness.
50joe
Trenton NJ
On my 96 5.0, which is probably the same, the spout is on the drivers side fender right by the firewall.
P
psychobiker
charlotte
sorry guy i had the book but cant find it. this spout connector seems to have two red wires in one of the pics, but ive got no connector comming off the icm. all the wires go into the harness. i do have a connector off the the distributor. where do the spout wires go to maybe i can trace it back. and of course its raing this morning. i really hope this is it cause i hate doing distributors. the spout code is the last one to fix....
P
psychobiker
charlotte
there is no spout connecter from icm, if u could tell me where its soupposed to go i could trace it back to the connector. right now it cranks but no spark at all
suggest you buy a Ford Bronco Electrical and Vacuum Troubleshooting Manual (EVTM), Powertrain Controls and Emission Diagnosis Manual (PCED), Service Manual CD .. ensure it will operate on your PC, tablet,etc.
Best you'll ever buy to maintain your Bronco!
billmcg
Here is where my spout is located if it looks like the connector coming off your distributor, then that is the spout
P
psychobiker
charlotte
i will get some pics up on friday, gotta work adouble to help pay for whatever parts im gonna need
P
psychobiker
charlotte
got battery for both camera and truck charging. would my initial charge to the battery cause something to fail because i went to the post and did not groun to motor. im gonna take out o2 sensor and clean it, check continuity on coil.
P
psychobiker
charlotte
this connector comes of the dizzy it has 5 contacts 3 on top two on bottom . middle on top touching the corresponding contacts has no continuity with the key on. could that be the reason my truck is not firing?? also i found what i thought to be a loose bolt right below that it was snapped off. goes in that hole in last pic
Elmomo
