92 needs lots of work
tabronco
so i picked up a 92 6cyl with under 100k on it for 700 bucks , right away before i can drive it i have to fix a bad brake line any one know what size i need the hard line in the rear is blown open. the steering is way off may need a new box. when you get a new one will it need to be adjusted or is it good to go from the store? the body is rusty but i like it for the price and it will be fun to work on.every thing works but the wipers and pass window . cheers everybody
Minnesota
GOOD LUCK!!!!!!!!!! I got ya beet at $300.00 for the 88 I'm driven all it needed was an alternator and water pump
Welcome to the Zone > . Post a couple of pictures when you get a chance.
Croneybones
Meadville, PA
I don't know the size, but I just had to redo my lines not too long ago. Just go to your local auto parts store and they should have lines there for you. Mine cost less than 20 bucks and I went from the front all the way back. Don't go cheap, get the coated stuff that won't crimp if you bend it too hard.
Virgil3rd
